driver headlight not working
I've read a lot of posts regarding headlights before posting this, but none really matched exactly what is going on with mine...
The passenger headlight works fine, as well as, the brights and the turn signals.
I replaced the bulb and the fuse is fine. My voltmeter broke (it figures) and I haven't had a chance to replace it.
Could this still be a healight switch?
Hey mp4, what ended up being the problem with your headlight? I'm having the same issue. I just took apart the headlight switch, and cleaned it up but it wasnt the problem. My fuses are fine. I don't have a multimeter either.
Over time the insulation on the wires inside the headlight body gets very brittle. (where you connect the headlight bulb.) If they touch, it might fry the wire enough to open the circuit for that light.
kingwoodpressurewash@gmail.com
12-11-2017 07:09 AM
MinnesotaJoe
02-18-2014 05:15 AM
