drivers side door handle doesn't work first time
This is pretty wierd and I just noticed it start happening today. After unlocking, if I pull my handle fast it doesn't full let go of the hook. Its like when you open the door a little bit and get a door chime but its still latched. If I do it a second time after that, it opens. If I slooooowly pull the handle up and then open the door, its also fine.
I only saw one guy have this problem on Search and his problem seemed to be cold weather. But its only 50 out. Any ideas?
I have the exact same problem with my door not fully opening from the outside, the first time I use the handle. Have you found a solution?
meem
07-28-2008 10:36 AM
Ragdoll
15
06-11-2008 03:55 AM
