during shifting, if the gas is pressed, the engine revs, much like a manual, problem is, this is tip
so all of the sudden during shifting, the engine will rev like it is in neutral between shifts, resulting in jolting into gear... someone please tell me i don't have to replace the whole transmission and this is just a small problem
there are two codes from the throttle; from the body- (17967): Fault in basic settings, and a code from the throttle actuator: Lower stop not reached... these are the only ones that would come up again immediately after i cleared it... the laptop died before i could get any codes from the transmission... luckily i haven't actually had time to install the new throttle body, so this could be the culprit...
