ecu error code
hi all
my car has a problem when pressure goes above 1 bar it starts to stutter.
vag com gave me this
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 T
Component: 1.8L R4/5VT MOTR HS D06
Coding: 04201
Shop #: WSC 06335
1 Fault Found:
16989 - Internal Control Module: ROM Error
P0605 - 35-00 - -
Readiness: N/A
Does this mean i have to change my ecu or my wett chip is bad?
Coding: 04201
Shop #: WSC 06335
1 Fault Found:
P0605 - 35-00 - -
Readiness: N/A
contact your Wett chip dealer. Tell that's the code your getting, they will check the memory. I remember I used to read about that code when people first started getting their ecu's chipped.
Alternative, You can run another ecu and should be ok. Everything in the bentley manual points to new ecu.
reefer_bob
08-14-2006 06:23 PM
AEGA4
03-20-2005 09:46 AM
donp
06-11-2001 07:36 PM
DavidG
06-15-1999 11:55 AM
