Ecu Fuse?
Ecu Fuse?
Im beginning to think my fuel problem is ecu related, and im wondering if there is a seperate fuse for the ecu. If so, which one is it, and where is it located. Id like to check the fuse before I take the ecu in to be checked..
thanks
-Steve
thanks
-Steve
Keeper of the Cash
Link to post about fuel problems? I highly doubt your ECU is the culprit here. Have you done. . .
a VAG to it yet to check for fault codes, and other measuring blocks? Replacing an ECU for fuel problems doesn't make any GD sense to me.
Re: Link to post about fuel problems?
No, I havent vag'd it yet because I dont own a vag. Ive been asking around on the forums, but no one is able to help me out I suppose. The reason I think its the ecu, is because a) im not getting spark ( I believe, I held the plug against the VC and didnt see spark) b) the fuel pump isnt going on with the turn of the key and c) when i hardwire the pump, and try starting it, it still doesnt fire. Is there an ecu fuse I can check, or a way to test the ecu? Heres the link to my problems:
-Steve<ul><li><a href="https://forums.audiworld.com/a4/msgs/2372849.phtml">https://forums.audiworld.com/a4/msgs/2372849.phtml</a></li></ul>
