EGainer - Tech article i wrote while doing my ignition switch... might help
Ignition Switch Replacement by Mike Tan
Readers are advised that Tech articles are for informational purposes only. No liability is assumed by either AudiWorld or the author for the use or interpretation of information contained within an article -- all decisions based on the data or information are the responsibility of the individual user. See the AudiWorld Terms of Use for more detailed information
The Problem:
Upon starting the car the key will rotate to the "Ignition Start" position and remain there rather than returning to the "Ignition On" position. This causes your starter to remain on even though the car has already started running and can damage the starter itself.
<img src="http://pictureposter.audiworld.com/34918/ig_1.jpg">
As seen by the highlighted portion, the plastic "ramp" has fallen off and thus the spring roller that would normally roll back to the "Ignition On" position sticks in the "Ignition Start" position.
Material:
- New Ignition Switch (Part Number 4A0-905-849-B)
- Philips Head Screw Driver
- 5/32 and 1/8 Allen keys
- T25 and T30 Torx bits
- 15/26" socket
- 10mm socket
Process:
1. Disconnect the Battery using a 10mm socket.
2. Remove the two(2) T30 Torx screws from behind the airbag. (one on each side)
<img src="http://pictureposter.audiworld.com/34918/ig2.jpg">
3. Disconnect the two highlighted connectors.
<img src="http://pictureposter.audiworld.com/34918/ig3.jpg">
4. Remove the 15/16" bolt holding the steering wheel on. And the two connectors as seen in the picture. One has a brown wire going to a black connector. The other is a set of wires going to a red connector. Remember what position the wheel is in, since you'll need to re-align it when you put it back on.
<img src="http://pictureposter.audiworld.com/34918/ig4.jpg">
<img src="http://pictureposter.audiworld.com/34918/ig4.5.jpg">
5. Remove the two(2) Allen screws using a 1/8" Allen key that holds the Steering wheel adjustment lever on.
<img src="http://pictureposter.audiworld.com/34918/ig5.jpg">
6. Remove the three(3) Philips head Screw holding the Steering wheel guard on. And slide off. Watch out for the Steering wheel adjustment lever that is fed through this guard.
<img src="http://pictureposter.audiworld.com/34918/ig6.jpg">
7. Remove the Female Ignition switch from the Male ignition switch.
<img src="http://pictureposter.audiworld.com/34918/ig7.jpg">
8. You can now remove the Male ignition switch that goes into the back of the Ignition tumbler via these two screw that are actually painted over with red paint.
<img src="http://pictureposter.audiworld.com/34918/ig8.jpg">
All done, just reverse the order and marvel at your working car once again.
The Problem:
Material:
- 15/26" socket
- 10mm socket
Process:
bronxnativ
07-13-2010 09:08 AM
