engine code p0171 ... is it o2 or maf
i have a giac chip and kn air filter: i got the code maybe 2-3 months after installation i do not know if it is connected to the problem.. the car is an 01 and has 58k miles
I get this code all the time p0171 lean fuel trim bank 1 if i remember correctly, i thought that meant that the first oxygen sensor was mal functioning and needed to be replaced, however i read somewhere that the mass air flow sensor is causing this problem??? does it just need to be cleaned...
thanks
thanks
Another trick is to disconnect the MAF. The ECU will fall back to the throttle position sensor for input it normally gets from the MAF. If the problem goes away, that's a pretty good indication that the MAF is toast. That trick is really useful when you have fuel related drivability problems that "come and go."
Cheers,
Cheers,
CrayonSpear
Pacific Northwest Discussion
10-25-2006 02:45 PM
Visti
16
07-20-2006 09:32 AM
quattroatl
06-06-2002 08:28 AM
