engine code P1137
Keeper of the Cash
Code Description:
Long Term Fuel Trim Add.Fuel, Bank 1 System too rich.
Problem part: N80 - Evaporative Emission (EVAP) Canister Purge Regulator Valve
Check the following:
Evaporative Emission (EVAP) canister purge regulator valve
Fuel injectors
Fuel pressure regulator and residual pressure
Fuel injectors
The canister is actually closer to the gas tank. The purge valve controls the flow of vapors into the engine to get burned. The canister collects them out of the fuel tank so they don't escape into the atmosphere.
So how do you know this is the problem with code P1137 (my problem also.. 97-A4-1.8T)? Other posts talk about the pre-cat O2 sensor and MAF sensors being the cause...
Please advise.
Please advise.
cparke
12-27-2008 06:16 AM
5150neo
VAG-COM Discussion
10-17-2003 04:27 AM
mmart6545
10-20-2002 07:35 AM
