Engine hesitation on startup.....bad spark plugs?
Old 04-29-2008, 09:43 AM
Member
SFexBOY's Avatar
Default Engine hesitation on startup.....bad spark plugs?
So the past couple days, I've had a slight hesitation when starting.....primarily after the car has been sitting overnight. Instead of it sparking upon turning the key, I have to hold it a couple seconds longer for it to catch....which it does.
I have NGK Platinum spark plugs in there now that I've been meaning to replace, but haven't gotten around to doing so. They have roughly around 40K miles on them =O.
Anyways my guess is a bad spark?
One other thing I'd like to mention, I bottomed out pretty bad on a speedbump over the wkend....is it possible I may have pinched a fuel line underneath the car? It sort of feels like the engine hesitates b/c its starved of fuel. Ideas?
Old 04-29-2008, 09:49 AM
Mr Mc Feely
RallyVermont's Avatar
have you pulled a plug to inspect yet? could be bad coils as well.
Old 04-29-2008, 10:04 AM
Member
SFexBOY's Avatar
Default nah i haven't to be honest....i plan on doing so this wkend...i just ordered the same set of Laser
Platinums (PFR6Q) since I was happy w/ the last set I had--stock turbo. I needed to replace them anyway....just hoping thats all it is.
Old 04-29-2008, 10:11 AM
EDness's Avatar
Default did you pinched a fuel line from jacking up the car years ago?
maybe it was someone else?
Old 04-29-2008, 10:13 AM
Member
SFexBOY's Avatar
Default yea i did....but i think that was a brake line....not bad and has never surfaced as a problem since
then...
Old 04-29-2008, 10:16 AM
Member
SFexBOY's Avatar
Default i think the sad thing here is I trust my 18yr old beater not leaving me stranded more than..
i do my B5 =(
Old 04-29-2008, 10:34 AM
Member
Casablanca Avant's Avatar
Default haha I know what you mean, I trust my 27 year old 911 over my B5 sometimes
and the best part is the 911 needs a new steering rack....
Old 04-29-2008, 10:37 AM
Member
freakness's Avatar
Default Spark plugs...coilpack/s...high resistance in the wires between the plugs and coilpacks
Dirty throttle body
Let us know if your spark plugs are black from running rich....
How's the battery and battery connections?
could be a lot of things... you should VagCom it just in case something funky pops up.
Old 04-29-2008, 10:42 AM
Member
SFexBOY's Avatar
Default thanks for the ideas of things to look for....sucks the weather has been crappy here lately...
i'll have to wait until saturday when I have time outside of work. I hate VagCom'ing my car....I always find probs I'd rather not see. lol.
Old 04-29-2008, 10:45 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default Probably the FPR or fuel pump.
Make sure the vac lines around the FPR are good. IIRC, there is a valve in the fuel pump the prevents fuel from backflowing into the tank. Maybe that's bad? Otherwise, a failing FPR has been known to cause delayed start up times when the car has been sitting.
Quick Reply: Engine hesitation on startup.....bad spark plugs?
