Engine Noise
Guest
Posts: n/a
Go to an autoparts store and get a cheap stethoscope, poke around the cold engine and see where the noise is coming from. Otherwise, it could be a dozen things, all unrelated and most not a problem.
You are running a 5w30 oil as specified by AUDI?!
Oh, and what year and engine is this?
Guest
Posts: n/a
Simple... Use a a thinner oil. As the car sits the oil drains to the pan. Then in the morning when you first start the car the thick cold oil has to be pumped through the engine. Until oil reaches the hydralic lifters they "tick"... use 10w/30 or 10/40 in the winter. Or a good synthetic 5w oil. This condition is normal..
MC Turner
MC Turner
Guest
Posts: n/a
...thing, even with 5W-30 Mobil 1. All hydraulic lifters are dry right at startup and make noise. However, it should not last more than a few seconds, so either Randall is experiencing something else, or he has a lifter problem.
Charles
Charles
Guest
Posts: n/a
This is a 98 A-4, 2.8 Quattro with 20,000 miles. I am using 5W30 oil. The sound is coming from the engine. It is not a belt or a fan. Sound is very similar to that of a car I had years ago with bad lifters. Is this car known to have such a problem??
A6 Jesse
02-20-2005 01:18 AM
bshin80
09-17-2004 01:41 AM
HaveANiceDay
12
10-08-2001 02:07 PM
