Engine not starting
Hello, I just found this site and really hope someone can help me.
In summary, my trusty 2000 A4 has decided today to give me some problems. I left work for lunch, parked the car, and when I returned it wouldn't start, just rapid clicking and rapid indicator light flashing.
When the engine didnt turn I noticed that the "Press Clutch to Start" display message and some of the other indicator lights were off. Normally it is on when the key is in. Upon trying to start the car again some of these lights came on but flashed while something else was clicking rapidly. I took the key out, waited a few minutes, and tried again. Still just a lot of clicking. I waited then tried again, this time when I put the key in all the lights, guages, and display were completely on. I tried again and it still wouldn't start. Frusrated, I waited a few more minutes, then tried again and the engine fired right up like nothing had happened.
I got home and parked the car, happy that I didn't have tow it. Thinking it was just a fluke, I tried to start the car again, and same symptoms. Now it won't start.
I would love if anyone can help me troubleshoot this. I am thinking it could be the starter but would that cause such strange dash light activity?
Thanks in advance.
Thanks in advance.
low batteries tend to cause ticking in the starter when there is not enough juice to crank the car. Poor connections will also cause this and other strange things.
Freakness, thank you for the response. I am curious how you can quickly rule out starter or other problem so simply? Either way, I hope your right! Thanks again.
if you can't get it running and have it load tested at autozone or sears.
Make certain that the cables are okay at all ends.. It's just kinda strange that the thing did eventually kick over for you. Sometimes if you let a low battery sit for a while, it will work again but you'll hear it struggle to crank.
Ok, I will try the battery and get back to you. I think it is strange too that it eventually kicked on. It wasn't sluggish at all when it did work, it just fired up. Am I correct in that I shouldn't jump start this car by pushing it?
do it for free. Still not sure that that's the issue but it's the easiest and possibly cheapest thing to check / replace.
I'd sooner remove the battery and drive it over in another car for diagnosis. If for some reason that it's fine and you have some kind of other electrical issue, you won't be stranded.
I've compression started (push-started) my audi a few times without issue.
A good/ok battery will charge overnight on a trickle charger then hold a healthy charge allowing you to use the car normally.
A dying battery can be charged but not enough to turn over the starter. If it's on it's way out then it'll work for a short while but then one day.....click, click, click, of the starter. How old is the battery in the car? If it's the original battery then it probably should have been replaced a couple of years ago as part of preventative maintenance.
This SHOULD be a simple solution for you...
Good luck...
Good luck...
