Engine is running VERY lumpy
Folks
Can anyone advise me why my engine is running very lumpy - it is most noticable whne the car is accelterating up hill in 3rd gear.
It is like the car has a very slight mis fire, and on Saturday when driving the car realy hard the engine did misfire at just over 3K rpm.
I don't know where to start with this one I hope that some of you could throw some ideas in.
Just on question I have - I have put in the standard plugs and not the platinum ones could this be having any effect on the performance, the plugs were changed about 3k miles ago???
Thanks in advance
Banger
Thanks in advance
Banger
...here's what I recommend. First replace the plugs. Yes, I know you just did them not long ago, but it's the cheapest part and sometimes overlooked. They should come properly gapped, if not, I believe they need to be in the .030" range.
If that doesn't do it, it's either your ignition amplifier (see pic) or your coilpacks.
<img src="http://pictureposter.audiworld.com/12690/ignitionamp.1.jpg">
On a '97, I'd put my money on the ignition amplifier (a $180-300 part, depending on where you buy it). Maybe that's just because it failed on mine, but it seems to be the culprit most of the time for misfires on nDBW cars. Here's how you test it: <a href="https://forums.audiworld.com/a4/msgs/1594531.phtml">Ignition amplifier / Power output stage diagnostic</a>
Try to find a VAG-COM so you can determine which cylinder the misfire is in and then you'll be able to tell if it's a bad coilpack or not.
Anyways, this is just the quick and dirty. There's SOOOO much info in the archives on this subject, and it comes up quite often, so try a search if you're interested in finding out more. Or, I'm sure someone else will chime in here and add to my suggestions. Good luck
Andy
Andy
Andy
Thanks very much for all this info, I have a question can you tell me what the swtich/plug to the left of the ignition amp (in the picture) is for, I disconected that plug (after advise from a slight under qualified person) and the car seems to run slightly better what is the function of the disconected plug or am I just imagining the car is slightly better???
thanks
Banger
thanks
Banger
Hmmm....not sure offhand. I want to say it's some type of secondary air solenoid, but I don't know. You plan on doing the work/diagnosis yourself....or taking it to a shop/dealer? Good luck
Andy
Andy
Buy an Engine Compression Tester @ Autozone for like $25 and test out each Cylinder. That should at least give you a clue which cylinder is misfiring or not functioning. It may be your fuel injectors.
maaliish
08-04-2006 03:06 PM
Jesster
12-08-2005 02:00 AM
