Engine Speed Sensor tooth missing on Automatic Transmission Flywheel
I was driving the car and all the sudden it stopped, so after I scanned it I got Engine Speed Sensor (G28) No signal. I check the sensor it was knocked out and further inspection I found out that one Speed Sensor tooth was bent, so I straightened as much as I could through the automatic tranny holes in the bottom.
Now the car only hesitates at 6000RPM(feels like its shut off) with the new sensor, so my question is can I place the speed sensor on the engine block location instead of where Audi placed it? I other words where the cam locking tool goes just by the oil pan. I know the VW VR6 uses the engine block G28 Speed sensor location instead of the Automatic Transmission Flywheel.
Car info:
Audi A4 1999 2.8L 5Speed TipTronic
Here is my error code if anyone needs to see:
Address 01: Engine
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D01
Software Coding: 06251
Work Shop Code: WSC 06335
1 Fault Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
Readiness: 0000 0000
Car info:
Address 01: Engine
1 Fault Found:
P0322 - 35-00 - -
Re: IMO, you are going to need to see a dealer or a good indy.
well if you thinking a dealer to replace for me, thats never gonna happen. Its working to a point for now so if it comes down to replacing it I will do it my self, I will never givemoney away to the shops. But I just wanted to know if I can relocated the speed sensor into engine block location instead of the transmission location.
A8AWD
23
01-17-2020 03:45 AM
Jim Castronova
04-13-2018 03:43 AM
