engine vibrations
I was driving to work today and my car started running funny. The engine is louder, and it's idling rough. When I hit the gas, it will accelerate, but the car vibrates. I know this sounds similar to one of the recent posts, but my problem is different. Even in neutral, it does the same thing. Fluid levels are fine, temps are fine. Any ideas?
Yeah sorry I left a few details out. CEL was flashing when it first started, then it just stayed on. The car is a 99 with the 1.8.
Is it safe to drive it home like this?
distance home -- out of boost, no heavy load as much as possible.
I've had about 10 coilpack failures and have either driven it to the dealer while under warranty or now to a safe location to change it out with the spare in the trunk...which I need to replace since yet another freakin' coilpack failure happened over last weekend.
My bet is his ICM is on its way out.
so unless you are a hands on kind of guy.. when its flashing, I usually suggest to take it in the shop.
I have been getting some rather odd "misfires" lately.. like quick misfires one after another under moderate load in a lower gear. I pulled the codes and saw I am running lean.. damn RC 440's![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Cheers,
Joel
Cheers,
Joel
I did a little research about the coil packs. If i disconnect one at a time and the problem goes away, then whichever coil pack is disconnected is the problematic one. Is this correct?
My second question is, if I determine that one of the coil packs is bad, can I drive with the bad one disconnected? I know that obviously I would only be running on 3 cylinders, but could that cause any damage to the engine? I have about an hour or so commute home. I don't want to damage my engine, but at the same time, that's an expensive tow.
will stumble further...telling you that it's working.
When you remove one and nothing changes, that's the bad one.
If all 4 make it stumble further, then it's probably the ICM.
I never got the coilpacks replaced by that "recall"/TSB because, for some reason, my VIN wasn't found in the database as part of it. However, I did get the notice from AoA in the mail and was part of the Class Action suit to collect around $800 for the 5 or 6 failures that qualified while it was under warranty, which most of those all happened in a row around 20k-30k.
There was a long duration in between that I only had 1 or 2.
Since then, I know that I've replaced 3 recently...in the past 6 months or so. IIRC, it was over 3, 1, and now 2. So, I guess #4 is coming up soon.
It seems to happen during the first day or two of extreme weather/temp changes whether it's really low or high. And, looking at the mileage, it seems to fall around 30k range when the weather changes quickly.
I plan to stop by the dealer tomorrow to get a new spare.
