Engine Won't Run... Need Advice
I've had an intermittent CEL for the past month or so and a noticeable loss of power and light loss of gas mileage - almost as if the parking brake was stuck up a notch or two.
Last Monday the engine shut off while driving - no sputtering, just off completely followed by a loss of power steering about 5 seconds later. I was only about 1 mile from my house, so the motor was still cool.
When I tried to start the motor from the side of the road it started, but immediately died, so I got the car towed home.
I picked up a Actron PocketScan to pull the codes (I know, a VAG would be better). The only code it threw was P0422 - Main catalyst effinciency below threshold (bank 1). I cleared the code and tried to start the car, which started, but immediately died.
The PocketScan also reports:
4 Incomplete Inspection / Maintenance Monitors (I THINK that means the system reported faults here):
-Catalyst
-Evap
-02 sensor
-02 htr
3 Ready Inspection / Maintenance Monitors (I THINK that means systems are operating normally):
-Misfire
-Fuel
-Comp
The car has 250,000 miles. The motor has about 80k miles (replaced a year ago w/ a used engine). The belts and tensioner were changed prior to putting in the new motor. The O2 sensors and Cat are all original - so about 250k miles, as are the injectors and FPR.
One thing to note is there has been a coolant leak for the past 4 months and I've been putting in tap water from gas stations (ick!). I don't know if the deposits could be hurting something in the motor.
Will bad emissions components keep the car from running all together? Any ideas?
-Catalyst
-Evap
-02 sensor
-02 htr
-Misfire
-Fuel
-Comp
AudiWorld Expert
fuel or spark. - You probably need to get a Bentley manual to trouble shoot your root cause and maybe get a VAG-COM - since you plan to do your own work and your car is so old.
