Engine wont start help!!!
#11
This vehicle was wrecked it's possible someone just put the belt back on without aligning anything , or the woodruff key holding the crank pulley is snapped.
If you remove the valve covers and check the actual valve position rather than guessing then use the leakdown with the piston at TDC you can see and hear which valves are damaged.
#13
I get that, but he's already cranked it and not found any compression with the cheapie tester, plus you can hear on the video the constant whirr of a non-compressing engine, which means both banks. So we already know there is damage in every cylinder, so what's the point of figuring exactly which valves are bent?
#14
Valves don't have to be bent, to get no compression.
If it's way out of time, valves are open at the wrong place so no compression. Valves are mostly damaged when they are just slightly out of time not way off.
#16
ok lets see so i started taking the head off but they wont come off...intake, plugs, injectors, hoses, belts, bolts are off but intake and head wont lose...first day of work will see tomorrow..i may considering just to replace the entire engine would be easier just maybe... here are some pics
#17
Did you ever check and reset the cam timing and do a leakdown test?
Looks like you are doing that head removal in the most difficult way possible. Need to unbolt the exhaust manifold or remove injectors. Did you remove the intake manifold or just unbolt it? Did you unbolt the water pipe on the back of the head.
I cringe looking at your pictures.
#18
i did not leakdown tested....in case is damage badly i may just replace the whole engine..but i unbolt the exhaust bolts is free..the coolant pipe on the back...injectors are free too...intake bolts are off too as well as head bolts...tb is off, the head is loose but the intake feels like is glue to the head wont let it go..i dont have a garage so im doing this in my drive way..i dont want all the parts in my drive way because one of my neighbors is always complaining about everything...drama queen!!! lol and today was raining most of the morning and i work from noon to 6pm then i got home and it started raining again....hopefully tomorrow will be a better day..
#19
Keep in mind that there are some steel roll pins that align the manifold to the heads, which may need to be knocked loose. I haven't done this job myself, but looking at it, I'd lever a piece of wood on the valve cover so that it caught the manifold in a way to lift it, and whack the free end down with a mallet. Find these pins and spray some PB, liquid wrench, etc. on them first.
#20
ok new updates!! i got the head assembly off... to me it seems that the valves hit the piston but piston looks fine no damage so far wil see tomorrow....i know now why the intake wouldnt come off really dumb thing i forgot four bolts on top of the intake...i know really stupid but thats sometimes how you learn the hard way!!! right??? any ways here are some pictures of the head and the pistons.. but im having problems uploading the pictures so i post them on my flickr profile here is the link
http://www.flickr.com/photos/63184884@N02/
