Enging Stalls Randomly!! Help?
I have a manual 97' A4 quattro. It stalls very randomly...
It usually starts in the morning when its been sitting all night, but if I come up to a stop sign and shift down to first and stop... it stalls. So far, it has restarted every time after I've tried restarting it a few times.
Its been doing this for a few months. It always starts back up but its so random when it stalls. It also smells like gas when I'm trying to restart it.
I have taken it to my mechanic and he cant figure it out. Very frustrating. Left the car with him for a few days and ofcourse it doesn't stall.
Anyone had a similar issue?
Thanks!!
Thanks!!
[QUOTE=alloyd85;24063894]I have a manual 97' A4 quattro. It stalls very randomly...
Thanks!![/QUOTE
I had a similar issue with my '96 A4 and it turned out to be the coolant temperature sensor. Does your coolant temp. gauge read normal? In any case, this part was inexpensive and not too hard to replace. Good luck.
Thanks!![/QUOTE
Thanks!!
Thanks!!
I definitely agree with AudiMick. It sounds like your ICV or maybe even your throttle body. The throttle bodies are pretty easy to clean on the 12v v6. My suggestion would be to remove that and check for carbon buildup. You'll be able to see if it's dirty right away when you take it off, there are DIYs how to do it too. Also if you want to start cheap look into seafoam. Running it through my fuel lines, vacuum lines, and crank case fixed that same problem on my 30v B5.
Best of luck and let us know.
score0412
Audi A3 / S3 / RS 3 MKII
35
07-06-2018 12:29 PM
onebrokenneck
06-27-2006 08:32 AM
b5s4
06-03-2004 11:26 AM
