Enngine noise 2.8-30v
Guest
Posts: n/a
I Have a 99-5 AudiA-4 2.8 Quatro Trip- Have taken car into dealer on 11/8/99 to have this noise checked out the tech heard the noise but wasen't sure what it was! the noise comes from the right sideof the engine this started at about 1000 miles and has dampend my enjoyment for the car. the dealer has called for the factory rep and said he won't be here until Dec 17 99? if anyone out there has had the same noise i would like to hear from them.
Thanks Don.
Guest
Posts: n/a
Its a metallic tapping noise that comes on when you first start the car in the moring its more apperant when you accelarate.its louder when its cold but remains when warm but not as loud. there is also a noise when you start the car its like arumble they told me it was the teninsor?
Don
Guest
Posts: n/a
but it's coming from the hood, somewhere near the windshield edge. Try it yourself. Lift the hood, and tap around there. You'll hear some kind of rattling sound. I've tried taping down the washer hoses, and I can still hear it. It almost sounds like there is something loose in between the two plates in the hood...
-PhilJ
-PhilJ
Guest
Posts: n/a
I can't say that I have that little problem, my engine starts just fine in the morning w/o any metal tapping. It's a little rough when cold, but once it warms up the engine smoothes out more.
Very strange, I'll pay more attention tomorrow morning when I leave.
AndyC
99 2.8qms
AndyC
99 2.8qms
Guest
Posts: n/a
...can easily sound like a mechanical tap. Went through that on an '83 GTi. I thought there was a bad lifter, but it turned out to be the exhaust manifold gasket. Reason for change in tone would be the expansion of the metals when hot. THis would somewhat or completely close the opening as the temp increases. Also, the manifold could just have a loose bolt or two, or it could be cracked. My only other guess would be a lifter, but it would probably quiet down completely after warmup, and probably wouldn't be noisy every time you start the car. Also, a lifter wouldn't become more noisy under loud; atleast not to the extent that you describe. Hope they figure it out and fix it soon! :-)
CHarles
CHarles
stevenknapp
10-31-2002 11:19 AM
