Erradic engine tempgauge, half way between middle and bottom; Coolant temp sensor or Thermostat?
My engine temperature gauge has progressively began to report lower and lower temperatures. Now no matter whether around town or on the freeway it, once warmed up it is only half way between the middle and C(bottom). I also noticed that it takes a lot longer for it to reach this temperature compared to my dad's 03 1.8t Passat. Is this more likely to be the thermostat, or just a bad coolant temp sensor? If it is the thermostat I know it is stuck open, but is there any way to check? I happen to have an extra thermostat that came with my timing belt kit that I never replaced, however I would prefer not to have to flush the coolant again as it is kind of a PITA. Also, would either of these throw codes I could check on the vag com?
TIA
TIA
is the oil temp normal?
<center><img src="http://pictureposter.audiworld.com/143/bad-temp-sensor.jpg"></center><p>this is a pic of my dash with a bad coolant temp sensor. the oil temp is normal, but the temp guage would bounce around while i was driving.
a bad sensor will throw codes.
Even if you have code it will be for the coolant sensor, the only way to find out (more)
w/o changing one and after that another is to get temp. meter, warm up the car and open very carefully the coolant reservoar, measure the temp and check if is the same as the VAG report.
200 seems normal for driving...chipped and driving aggressively gets me to 210-215.
if you live in the north-east (very cold recently) you car wouldnt warm up if you had a stuck open thermostat.
with a broken coolant temp sensor, i could make the needle bounce around if i did third gear wot runs. also, your mpg will get ****ty.
driverofquattro
02-19-2003 11:40 AM
