Every dealer I called is claiming they have no idea what I'm talking about when I say a repair kit
#21
i swapped cp's still cyl 2 misfire, swapped plugs as well as fuel injectors, same issue ... checked for leaks and used carb cleaner to test, still nothing, and it throws a open circuit code on the vag ... meaning it would be an electrical issue ... right? So i feel like that leads to the harness. When my cel light would come on ... it slowly would come on more and more often ... started with once a day, then twice a day, and then eventually it was consistantly on ... sounds to me like there was a loose connection from the pin to the connector ... and it finally fried. Once the issue was continuous it wouldn't even start, then i noticed my ecu fuse or whatever was blown, replaced it and now the motor starts but still has the misfire. I'm thinking when the pin/wire shorted it blew the fuse to the ecu.
Does this all make sense? Everything seems to lead to the wiring/pins ... boosted had the same codes/symptoms as me and it was his pin ... what do ya think?
Thanks
Thanks
#22
does it look corroded or melted or anything?
anyway, if its the wiring and their are 4pins...you'll need two repair wires.
either solder or butt end crimp them on to the cut harness.
you'll need to push the pins out of the existing connector or just buy a new connector.
mattarios2
04-01-2007 11:46 AM
mattarios2
03-31-2007 08:17 PM
GTi 1.8Turbo
03-06-2003 12:59 PM
