expansion Valve on AC Line
1 Post
Refer to the Bentley Workshop manual for exact details on the procedure and equipment needed to perform replacement of the accumulator, compressor and restrictor.
Has the air conditioner stopped working on your vehicle?
Well, Last summer I replaced the Condensor, Acculumator, AC Compressor and a couple of hose. The AC Compressor was from Ebay. Then I vacumed the line and charged it. After driving for a couple of days, right in the middle of winter I lost my heat. Troubleshooting it I found the Clutch of the AC Shorted, which was blowing my Heater fuse. 2 Function fuse.
I could not figure out why the clutch Shorted. The only thing I did not replace was expanision valve. If you say it is in the Hose, then I had changed the hose. The other Thing I wonder is if My Climate Control Has a problem where it told the Compressor to constantly run. Not sure why but it would do this, so Summer is coming and I need to have AC in the CAR.
1 Post
Do you have access to a VAG-COM interface and the Bentley Manual? You should see if there are any fault codes in the module for the HVAC.
bigdawg56
03-23-2017 01:33 PM
A8nightmare
06-12-2011 09:34 PM
AndrewsQuattros
06-23-2003 07:23 PM
