Fault code: Knock Sensor 2 G 66 signal too low
Hello,
My VAG-Com is reporting the following DTC on my '98 1.8T:
"Knock Sensor 2 G66
Signal Intermittent
Signal too low."
Can anyone offer any advice on this? Does a faulty knock sensor affect boost?
Where is the g 66 located on the engine block? And what's a good source for a new/used unit other than the dealer?
Thanks in advance for any help. Please, no comments to the effect that I can look this all up in Bentley's. I'll be getting my manual next week.
Thanks,
Jeff in Boston
<krasner@globe.com>
"Knock Sensor 2 G66
Signal Intermittent
Signal too low."
Thanks,
Jeff in Boston
<krasner@globe.com>
<center><img src="http://pictureposter.audiworld.com/102074/component_locations_overview.jpg"></center><p>
https://forums.audiworld.com/a4/msgs/2577828.phtml<ul><li><a href="https://forums.audiworld.com/a4/msgs/2577828.phtml">click</a></li></ul>
boost should stay the same, timing will not advance under boost past 0 or top dead center. So the car will feel slep under boost. It's about a $70 part and an hour or less of labor depending on which sensor it is. There is one under the intake manifold around cylinder 2 or 3, and then another towards the back of the motor under the intake manifold.
G66 = KS2 which is really #19 in the picture a few posts below. I replaced KS1 a few months ago and it was in location #20 on my ATW engine.
My car has Green (KS1) and Blue (KS2) sensors. Colors are confirmed in Bentley wiring diagram #79/4. I found the right plug and followed the wire to determine the correct location.
closed loop
Audi Original "S" Cars
04-29-2008 07:29 AM
paulroad
VAG-COM Discussion
10-02-2007 05:48 AM
DaveInSaltLake
Audi 100 / A6 (C4 Platform)
9
03-26-2007 10:15 PM
Too Cold NB1.8T
VAG-COM Discussion
11-20-2005 06:29 PM
