feedback need on k04 chips
i just want to know what chip i should go with for my k04.some hp numbers would be great. thanks
here are my options:
1-ams stage 3+ from abt ams
2-Wetterauer chip
3-GIAC k04 chip
what do you guys think?
2-Wetterauer chip
3-GIAC k04 chip
If you just want a regular k04 chip, go GIAC. But there are stronger ones out there that you will like more.
If you are 97-99.5 then you can get the pc16 file, which is from GIAC. AWE offers is. If you are 2000 you can get the file j31 which is from GIAC. You would have to go to your local GIAC tuner for that file.
With either of these files you will need to run bigger injectors, adj. FPR, and a FMIC is highly recomended.
the choices are just the ones i listed. also will not be going pc16 at any point.
out of the chips i listed which will be the most power full?
that is the MTM K04 setup, everything from the head back is modified, the exhaust mani, a new K04, new cat, DP, exhaust, FPR, spark plugs, and ECU 245hp and 264ft pound of torque.<ul><li><a href="http://www.hoppenmotorsport.com/a418ttuning.htm">Hoppen - MTM</a></li></ul>
hehateme
05-15-2005 09:41 AM
pac1085
03-28-2005 04:28 PM
TomRitt (Homebrewed)
01-17-2004 09:25 AM
PDXA4
03-29-2002 10:09 AM
