Feeling hot around the lower right leg while driving the 96B5A4
Not sure what to make of this so I'm reaching out to this board for some help. Here goes, after about 20 miles of highway driving with speed of 65mph, I felt hot around the lower portion of the driver's side. I did not feel this same hotness while driving in the city at lower speed. The other side of the car did not get hot while I was driving at 65mph. None of the warning lights are on when I started to feel this heat. The heater is turned off so that cannot be the cause. I suspect that the firewall may be cracked and letting the heat from the exhaust leaking through. Can someone confirm what I am experiencing is also what you went through and know how to fix the problem?
If it bothers you get some foil type insulated material from a racing shop, pull the carpet and extra insulate the floor there.
I "used" to have this problem and I "think" it was solved when I removed my belly pan. I'm not sure and this may all be in my head but I'm asking you in an attempt to finding a solution.
Jacked up the car and found that the left catalytic converter cracked and leaked the exhaust heat causing the floor to get hot. Bought a pair of universal cat conv from Magnaflow online and will swap these out as soon as the new ones are delivered.
wai2
Q7 MK 1 Discussion
09-01-2008 02:19 PM
eastcoasta4
35
01-27-2005 07:08 PM
