A few questions about brakes
I found a few posts about real brake pad wear faster than the front one. Is it norma?
Does both front and real are in use when braking? Shoud I choose the real brake pad with long durability as the high priority? Or just use the same standards for both front and real ones?
Thanks,
Thanks,
My rear pads wore out sooner -- don't know why but they were all (f&r) replaced under warranty. For driving, you use mostly your front brakes. I used the same type of pads when I replaced my rotors.
do you mean rear brake pads?
brakes are quite easy to change on the A4Q... the FWD has a much more difficult rear configuration than the AWD.
If you dont think that you need more braking power then just buy the original brake pads/rotors. If you think you need more stopping power then get larger brakes.
high priority... is being alive a high priority for you? If not... then dont worry about brakes... you dont need them.
knox
9
02-11-2002 09:06 PM
