Finally getting to the A4 trans, questions
#11
Forward gears work lots better, reverse is a no go, makes a weird whirring sound (bad pump maybe). Off to the yard to find another DDT.
#12
No DDTs at the two yards I was able to visit. Will try more this week. I scanned the car and came up with these. Could the 1st one be related to the lack of reverse and weird sound?
Address 02: Auto Trans
Controller: 8D0 927 156 BM
Component: AG5 01V 1.8l5VT USA 8508
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00526 - Shareware Version. To Decode all DTCs
27-00 - Please Register/Activate
The second one is just a brakelight code. I looked at some of the real time data, and I can see the ECU thinking the trans is in R, 1, and R but neutral never occurs. When it is in neutral it acts like it is in drive. Ideas? Thanks.
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
#13
The transmission controller only knows where the shifter handle is by the multifunction switch, F125 it is called on the schematic. I would guess that the switch is bad, or the connector(s) are not making good contact. I suppose that you could try disconnecting the electrical connectors (multifunction switch and solenoids/sensors) and see if you get reverse in limp-mode. If no, would think that this confirms an internal mechanical problem.
#14
Really good idea to see if it is an internal issue! Where is the multifunction switch plug on the transmission? Is it the main circular bundle of cable?
Of note, I put it in Park, and vag-com see's it in P yet it acts like it is in Drive only slipping... In Drive gears it does move forward. No, PRND are not all lit up. I really appreciate the help.
#16
New used trans acquired for 300 otd, and new TCU ordered for 50 ob fleabay. Will swap it all out when I get back from traveling. Thanks for all the support.
07dreamer
08-10-2002 11:34 AM
