finished the dual rear brake light mod using the rear fogs <flamesuit is on>
<center><img src="http://pictureposter.audiworld.com/54666/brakelightmod.jpg"></center><p>
before and after
<img src="http://pictureposter.audiworld.com/54666/brakelightmod1.jpg">
some notes while i did the mod:
i only had to weld one side of the rear circuit to get both lights to come on
with this mod you shouldnt use the the rear fogs are those will illuminate the rear deck brake light as well, therefore your brake light will be one all the time
the whole soldering with this mod shouldnt take more than 10 mins. its a cheap and easy mod.
before and after
That would provide a one-way connection so that the fogs light up with the brakes, but the brakes don't light up with the fogs.
i dont know to much about diodes so im clueless which one i should buy. but i dont use the rear fogs anyways but good point
