finsished the install, filled all my fluids up to level, oil and coolant.
took a spin around the block, came back checked levels and I am dripping coolant big time, what do I do?
check the coolant supply line to the turbo
it is 19mm fitting on the turbo. Did you use a new crush washer? Also, check under the car while it is running to see if you see any leaks. Hope this helps. If you need help call me or im me. I can't find my cell phone so you can call me at home 202-737-2521
