Flame suit on:Will just adding a chip or K04(apr, awe) do much or any harm to engine, clutch..etc
#12
Keeper of the Cash
amount of fuel to air ratio, as well as controlling timing and other parameters.
You need to say far, FAR away from MBCs.
#14
k03 is the smallest, the k04 is a bit bigger, but not much. in reality they use the same internals, just a bit bigger wheels. the gt28rs is bigger and can flow about 350hp.. a step up from that is the 2871 which is a similar turbo to the 28rs, but has a bit larger comp wheel.. those are the most common and what you're lookin at
k03 < k04 < gt28r < gt28rs < gt2871r
#15
saying that im driving normally about 90% of the time, but GT28R and up will do damage?
#16
depends on what engine you have and well you execute the setup.. but, personally, i would have no problem running up to 100bhp/rod on an aeb with a good tune, proper fueling, and a good intercooler.
there's a guy on motorgeek that ran a k26/t04e on his stock aeb for a long time, never opened it up.. that car has now been running a gt3071 over 400bhp (almost 350whp). many will tell you it can't be done, but it has.. the aeb is pretty stout. i know nothing about the capabilities of the later 19mm wrist pin'd 1.8ts
djnelsen
05-16-2002 10:02 AM
PK
04-29-1999 08:34 PM
