To Flush or Not To Flush!!!
My coolant level fell below MIN and in buying antifreeze, its instructions call for a flush of the system. The Audi owners manual seems to imply just an addition is necessary. Which do you recommend??
Please use the dealer/OEM fluid, as recommended.
I think it's G12 or something like that.
If you're under 50k, I'd say just add. If over, flush it. Nothing is "lifetime", especially when you starting mod'ing these cars.
Don't flush the cooling system unless you switch to a different kind of coolant (G11 to G12), or unless you had some sort of contamination.
You should change your coolant each time a metal part in the cooling system is replaced. That means with each new waterpump you should get the coolant replaced. A flush won't hurt, but if the old coolant was clean, then I don't see the necessity.
If the coolant was a little low, just add a 50:50 mix of water* and antifreeze.
*Yes, I use destilled water
You mentioned purple G12 Plus the other day. Were you kidding? I actually asked the parts guy at a VW dealer when I bought new spark plugs, and he was rather unamused. ;-)
so, I have to go to the dealer, I guess. I bought Peak, which had the Ethylene Glycol. Does it have to be that specific (i.e. G12)???
The G12 in gallons was a deal, but the G12+ in liter bottle is not, compared to Pentosin..
ayap
12-15-2023 05:27 AM
MingsS4
11-08-2009 08:49 AM
MuRaN0Daddy
10-03-2005 09:48 PM
bluenote
10-16-2003 08:09 AM
