flywheel bolt 12mm triple square? confirm pls!
No. They're a 12 pt bolt, about 17mm as I recall. You don't need a special tool, just a 12 pt socket. And you aren't supposed to reuse them, as they're a stretch bolt. You tighten to the torque spec, then add another 180 degrees.
Sorry shredr, I was thinking today I was wrong. The ones I described fasten the flex plate to the crank on the auto. The clutch ones look like this:
http://www.ecstuning.com/Audi-B5_A4-..._Bolts/ES2152/
![](http://c1552172.r72.cf0.rackcdn.com/9384_x600.jpg)
yes that should be a 12mm triple sqaure tool you will need.
computrtutr
06-15-2008 06:23 PM
Edge85
10-05-2007 07:01 AM
DARKiGOD
10-13-2006 07:56 AM
CURSH[silverbullet]
01-27-2005 07:36 PM
