Follow-up question on re-installing spark plugs.....
...I was doing a search of the archives, and I saw a post stating that spark plugs should not be reinstalled once they've been in the car. This is due to the crush washer. Any truth to this?
If I reinstall the plugs that are in there now (only 3,000 miles on them), will I have problems with them loosening over time?
off the plugs? I used to have my plugs out of my Corrado weekly to blast the carbon off them, and I never had one loosen.
You should be fine.
You should be fine.
...hate to waste money on new plugs if they're not really needed.
I think I'll add my anti-sieze, reinstall the plugs and then check then retorque them after a few hundred miles.
After fouling plugs in my bike after adding an exhaust system I took the plugs out three times and had to clean them till i got the jetting correct. I have never had a plug come loose. Just put them at the proper torque..they will not loosen up.
If you look at it and it has a not been fully compacted, it may work. Just don't over tighten.
Good luck,
Peter
Good luck,
Peter
chenishead
02-22-2009 08:03 PM
4showa
01-26-2004 08:41 PM
