Found a leak when chaning tranny fluid - should i be worried
the only part that seems to drip oil is that area - and that is where the clutch is at - and there is no fluids in there - where the hell is the oil coming from
You might figure out where its coming from first. That looks like a reasonable size leak if your getting drips like that. At first glance, it does not look like its coming within the bell housing(ie trans imput shaft seal or eng RMS). My guess is that its coming from the motor(oil pan seal, tensioner gasket,etc.).
there is a plug behind the mount for the shift gate, mine backed out to the point I was getting a small leak. Major PITA to tighten, requires a T60 Torx and the trans mount has to be removed to tighten it. Another clue that the leak is from there, the more it backs out, the harder 4 3 downshifts become.
UrSoccer_mobileĀ®
06-30-2008 12:13 PM
