Front suspension popping noises...any ideas? All CA's and TRE's have been recently replaced.
makes a metalic rattle noise over bumps, and some shifting noises if I turn. possibly shock blown? worth a look.. I too feel in through the floor, and if i go over a hill (where goes up and down quickly) i can feel the suspension kind of max out and then when it comes down i feel the "popping," which i attribute to the space in the spring that is otherwise taken up/reduced by the shock. Mine is completely blown, not just worn out, so i think and hope this is my only issue. Suppose to have it replaced in the next week or so and ill post up my findings.
Control Arms? I agree with Picnicbob......check the sway bar links for correct tightness and is it stock ?
I was getting a knock/pop when giving the car throttle in 1st gear. It turned out to be loose top nuts on the top of both motor mounts. I tightened them both as hard as I could, and the noise is completely gone.
