Front wheel wobble......as if the wheel is going to fall off....
Old 10-06-2003, 11:04 AM
  #21
Member
SCd_Walter's Avatar
Default oh yeah
btw - ben can probably get any tool you'd need if its portable (hand tools type)
that's if I don't get him fired for bringing all the stuff to my place first!
=P
Old 10-06-2003, 01:15 PM
  #22
odelay12v's Avatar
Default Re: Boy...that sure does look like fun.
yes the symptoms you described are the same as mine were. how was i able to tell on the play.. well mine was really bad where the wheel would wobble even nonrotationaly sortof from pass to driver wise..which i thought was wrong so i got under it and found a spot that seamed to seperate looked different than driver side.. just compared the two sides.. and that one looked different as you saw in the photo..ok hub shark i did buy it..
ball joint tool came from here...http://www.zelenda.com/
and hub shark came from here..
http://www.thetoolwarehouse.net/shop/OLD-7325.html it was a $450 tool for $257.. only way to do it unless you want to remove your hub from the car.. then you have to go to a machine shop[ and have them press the old bearing out and the new bearing in with the hub shark no alignment is needed because you dont have to disconnect the whole hub..i was useing my bentley manual and the crappy instructions that came with the hub shark... let me know if you have any other questions hope that helps not shure if i hit all of your questions..<ul><li><a href="http://www.thetoolwarehouse.net/shop/OLD-7325.html">http://www.thetoolwarehouse.net/shop/OLD-7325.html</a</li></ul>
Old 10-06-2003, 02:57 PM
  #23
Andy_FL's Avatar
Default Yeah, there's some play in it.
Jacked it up with the wheel a few inches off the ground and used the rod from my jack as a lever under the tire....probably 1/4-1/2", not as much as I would've thought. And to confirm, I tried the driver's side and got no play. So now, when I have more time, I just need to pinpoint the wiggle I guess. Fun fun fun....
Andy
Old 10-06-2003, 03:03 PM
  #24
Member
Yippers®'s Avatar
Default :( .. doesn't take much play to translate into the wobblies. Here's hoping it's a joint and not the
bearing. Bearing looks to be a PITA ..
Old 10-06-2003, 03:17 PM
  #25
Andy_FL's Avatar
Default Yeah, no kidding...
I did notice my TRE boot has separated, but I watched closely as I wiggled the wheel and that doesn't seem to be the source of any play (but it will be soon...if I don't replace it). Plus, I've had this wobbling problem for a few months probably and the torn TRE boot is recent. Argh, add it to the list....
Andy
Old 10-06-2003, 03:30 PM
  #26
odelay12v's Avatar
Default yea agreed with yippers but from what you say sound like bearing..let me know if you tackle it.....
I am in kansas city where are you?
Old 10-06-2003, 03:35 PM
  #27
odelay12v's Avatar
Default if you start to get abs erors which i did.. the wheel was wobling so much the abs speed sensor...
was giving error readings.. it was bad affraid my wheel was goingot come off..lol but it did not..
Old 10-06-2003, 09:12 PM
  #28
Andy_FL's Avatar
Memphis, come on down ;-)
tylor
08-08-2006 02:06 PM
TittieTwister
04-21-2006 01:18 PM
jchomme
9
01-13-2005 02:18 PM
jyoteen
12
12-25-2001 03:52 AM
Quick Reply: Front wheel wobble......as if the wheel is going to fall off....
