Fuel filter getting changed tomorrow
use a T40 or T45 to unscrew the triple square screw that holds the clamp shut. Wedge a hammer up in there between the tank and the chassis. 4 bolts are all that is required to get the tank loose enough to make it work..
YES YOU CAN DO THIS ON JACK STANDS, and you dont have to get gas on ya.... use an oil pan and open the ends of the filter slowly so the banjo bolts give the filter time to drain out slowly.
Wear rubber gloves and you might get 3ounces of fuel on you at MOST.
You people are so lazy.
loxx0050
07-20-2003 02:03 PM
S4@last!::Now B7 RS4
03-19-2002 05:14 AM
