Fuel Gauge Update: So I put in the new "used" cluster yeterday....
and it looks ok. I go to the gas station and fill up, and hence, it's exactly the same. I drive 5 miles, and my gauge says I've used 1/4 tank of gas. ARGH! On top of that, there are a bunch of bulbs blown in this one, hence you can't see anything at night!
I turn on the car this morning, and the gauge works? wtf. I fill up again, and all is steady and seeming to work fine. Could it be the new sender was jammed and now is ok? If so, I'm going to put my original cluster back in. If the gauge works, I'm golden. If not, then the used one needs to go back, which it is, and I have to find another one.
Moving parts are a pain in the ***! I also have the sneaking suspsicion that gauges really can't go bad if they still work somewhat, it has to be the sender. Otherwise my gauge would show F or E at all times.
End of rant.
End of rant.
or it just started working. Shop is taking back the used sender, no questions asked, so that's good. Now I just have to put the original back in and hope it works.
RKA, you on any of the messengers?
Woodsie3
11
10-12-2018 05:01 PM
68_220
VAG-COM Discussion
03-28-2009 09:44 AM
Dirkv
9
02-21-2007 05:04 AM
