Fuel Pressure and manual boost controller
Anyone know what bar fuel pressure the stock fpr is in a 98 a4 1.8t? iirc its a 4bar?
Those of you running manual boost controllers what ones do you like?
Also I assume that those of you using manual boost controller arnt using the n75?
Many use the N75 and MBC.
Not really to raise the boost, but to controll boost spikes. The N75 has been known to run very smooth with BT applications.
I think a few people here like the Forge MBC. VAST sells an MBC that is decent. ASP too.
IMO, run a boost machine.
BeeeJ (BJC) do you know how high you can turn you boost up with it? Do see it in the specs
Im looking for somthing that will allow up to 33 psi or so.
Im going to be running 18-20 psi on pump and 30-35psi on c16.
Just want somthing to help keep things smooth.
