Gabe Ross's Build Thread
Hey there Audiziners, I am currently in the process Building my B5 A4. I am going with a Precision Turbo 5857 DBB, the power goal for now is 400FWHP+ and 600HP when I build the head. Running an AEB 1.8 motor... Usp Motorsports is going to be supplying the parts, install, and software upgrade. I will be updating this as everything goes along. Thanks for looking!!
**UPDATED: 11-20-13**
Car is making 460whp on E85 @28PSI
Mod List
Engine:
AEB 1.8L
JE Pistons 8.5:1
Integrated Engineering Rods
ARP Head Stud Kit
Main Bearing Set
Rod Bearing Set
Thrust Bearing Set
Knock sensor
OEM Head Gasket
Crankcase Gasket Set
RS4 Motor Mounts
034 Transmission mounts
034 Snub mount
Usp Motorsports custom catch can setup
Turbo/ECU:
Pag-Parts Turbo kit(Manifold,Hardware,Lines,Fittings,Gaskets,Intak e)
Precision 5857 Dual Ball Bearing Turbocharger all v-band
Eurodyne Maestro Tuned by Chris Green @ Usp Motorsports
Forge 007 DV
Tial MVS Wastegate (38mm)
Precision 600hp core w/ custom Usp Motorsports Inter-cooler Piping
3in MAF/Harness
Greddy Profec B SpecII Electronic Boost Controller
K&N cone filter
Fueling:
E85
Bosch 044 In-Tank Fuel Pump(feeds surge tank)
ID 1000cc Injectors
Radium Surge Tank w/Walbro 400E85 Built in pump and fuel pressure regulator
Lines and fittings
Integrated Engineering Fuel Rail
Exhaust:
Custom Usp Motorsports 3in Down-Pipe/3in Down-Pipe back exhaust all V-band
Magna Flow Muffler
Drivetrain/Transmission:
Clutch Masters 725 series Twin Disk Clutch w/custom pedal stop
Raxle - Drive Axles
JHM Shift Linkage
JHM Weighted Delrin Shift ****(knurled)
AWE DriveTrain Stablizer
Suspension:
ST Coilovers
Stern Adjustable Upper Control Arms
Brakes:
ECS OEM BBK Audi A8 Rotors(slotted), OEM Audi TT Carriers
Hawk Performance Ceramic Brake Pads
Usp Motorsports Stainless Brake Lines
Interior:
Corbeau Racing Seats
5 Point Corbeau Racing Harness
Custom VEI Vent Gauge(boost and AFR)
Exterior:
OEM B5 S4 Front Bumper
OEM B5 RS4 Grille
Depo Ecode Black Housing Headlights with HID
Pearl Yellow PlastiDip DipYourCar.com
Wheels:
(Street)Team Dynamic Pro race 1.2 18x8 with Nitto INVO Tires
(Track)Stock 15” Wheels with Mickey Thompson 24.5” Drag Slicks
![](http://i1052.photobucket.com/albums/s459/FonzieDYC/DSC_0254_zpsf13f012d.jpg)
[wrench][wrench]
![](http://i99.photobucket.com/albums/l315/gaberossi/turbo.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs757.ash1/164888_479442663282_112756298282_5910543_4793684_n.jpg)
![](https://l1.sphotos.l3.fbcdn.net/hphotos-l3-snc4/hs620.snc4/58081_479442728282_112756298282_5910544_121894_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1357.snc4/162990_479442803282_112756298282_5910546_4226363_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs692.snc4/63211_479442893282_112756298282_5910548_4483020_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs821.snc4/68101_479442983282_112756298282_5910551_1142379_n.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730361.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730360.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730362.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730363.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730364.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730380.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730379.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730373.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730375.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730369.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730402.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730381.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/183322_1286441016679_1699797502_500712_1529818_n.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/185639_1286441496691_1699797502_500717_43468_n.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/dyno.jpg)
http://www.youtube.com/watch?v=kUZV6F2ld_8 ***needs new muffler not exhaust***
![](http://i99.photobucket.com/albums/l315/gaberossi/b5.jpg)
quick cell phone video
http://www.youtube.com/watch?v=JjAPBrUkzNg I did some detailing on my car today and the paint came out like glass, figured some of you will enjoy these pictures....some are blurry but forgive me it was taken on my phone
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730422.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730421.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730414.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730417.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730418.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730419.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730416.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730415.jpg)
Dual Ball Bearing Billet wheel 5857 turbo,1.8... full boost on a cool night will be before 4k and when its hot out then i see full boost at 4500rpm
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730411.jpg)
took a couple pics over the past few days...
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730435.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730434.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730433.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730436.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730440.jpg)
![](http://i99.photobucket.com/albums/l315/gaberossi/SL730441.jpg)
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/205051_1990241076001_1242577494_2359885_3349118_n.jpg)
![](https://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc6/206906_177100165675961_155542377831740_428222_1080536_n.jpg)
Mod List
Engine:
AEB 1.8L
JE Pistons 8.5:1
ARP Head Stud Kit
Main Bearing Set
Rod Bearing Set
Thrust Bearing Set
Knock sensor
OEM Head Gasket
RS4 Motor Mounts
034 Snub mount
Turbo/ECU:
Forge 007 DV
3in MAF/Harness
K&N cone filter
Fueling:
E85
ID 1000cc Injectors
Lines and fittings
Exhaust:
Magna Flow Muffler
Raxle - Drive Axles
JHM Shift Linkage
Suspension:
ST Coilovers
Brakes:
Interior:
Exterior:
OEM B5 RS4 Grille
Wheels:
[wrench][wrench]
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/208298_177100269009284_155542377831740_428224_4425390_n.jpg)
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/198265_110595929021329_100002127664929_96694_5172530_n.jpg)
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/189928_110595949021327_100002127664929_96695_1953935_n.jpg)
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/198915_1919200743983_1360950823_32274654_8101476_n.jpg)
i know the chick isnt a 10 but these pics were for free so im not
![](https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/189309_1921373154346_1242577494_2280935_6168630_n.jpg)
http://www.youtube.com/watch?v=pvwUXv_yXus
VERY nice car. Seems like it get's up and goes pretty good. My S4 is stage 3 and it climbs just like that. I have an A4 now that I'm rebuilding the bottom end and getting ready for a big turbo build. Not as extreme a build as your's, but looking to get a nice daily driver with ~300HP at the crank for my commute to work.
My S4 only has 57000 miles on it and isn't driven every day. The A4 will take that duty over from my allroad. The allroad is a 2.7t with GIAC chip. It's just been done up with a TB, water pump, etc. But maintenance is a Biotch on the allroad. Good luck with your set up.
Thanks joe, the car really gets up and goes for sure, it gets the adrenaline pumping lol...s4 or sport quattro is my next car once i finish this one
heres a sneak peak at the promo video for P0is0n Performance
http://www.youtube.com/watch?v=RcDhA...layer_embedded
You should be able to edit the title when you go to the edit page. If you cant you might just need to ask a mod to activate that option for you.
Hey everyone, I just went through a bunch of drama between work and crazy gf's but I'm back lol!! Got some new plans for this b5 so I'll keep you guys posted. I just had Clutch Masters Make me this 725 series clutch, took some time to get but I finally got it! ![Name: image1.jpeg
Size: 189.2 KB](https://www.audiworld.com/forums/attachments/a4-b5-platform-discussion-1/83841d1501531836-gabe-rosss-build-thread-image1.jpeg)
![Name: image.jpeg
Size: 150.0 KB](https://www.audiworld.com/forums/attachments/a4-b5-platform-discussion-1/83842d1501531836-gabe-rosss-build-thread-image.jpeg)
http://youtu.be/vD22cTGLh9o http://youtu.be/3bvD_ruPmQI Heres a quick shot of the car while I wait for the Radium Surge Tank with a Walbro 400E85 Pump:: Radium is proud to release the first ever fuel pressure regulated surge tank. The innovative FST-R (Fuel Surge Tank - Regulated) is a fuel surge tank that houses a single internal fuel pump and has a fuel pressure regulator integrated in the top cap. This revolutionary idea eliminates the need for an external regulator along with the extra hoses and fittings associated with it.
![Name: 139d19ff-70cb-42de-9064-9add9cdb26b2.jpg
Size: 776.5 KB](https://www.audiworld.com/forums/attachments/a4-b5-platform-discussion-1/83843d1501531836-gabe-rosss-build-thread-139d19ff-70cb-42de-9064-9add9cdb26b2.jpg)
a shot of the tank![](http://radiumauto.com/admin/uploads/FSTR-FULL1.jpg)
![](http://radiumauto.com/admin/uploads/FSTR-TOP1.jpg)
![](http://radiumauto.com/admin/uploads/RadiumProd-5.jpg)
Oh Yeah I purchased an s4 bumper for the car![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
![Name: image1.jpeg
![Name: image.jpeg
a shot of the tank
![](http://i99.photobucket.com/albums/l315/gaberossi/b52.jpeg)
