Gathering TB parts: Can I run preston coolant or G12 only? Should I also replace the...
tensioner lever and timing belt dampener? Or is it ok to just replace the rollers?
My car is a 1998 2.8Q with 150,000miles, its due for its second TB.... Hoooray!!! Decided to do the TB now since my water pump is leaking like a river....
There are so many different kits... I really liked the Blauparts.com kit but it does not include the tensioner lever and TB dampener.... Fun fun gathering these parts.
3.) Is replacing the cam seals and the front main seal a pita compared to the entire job?
4.) Does the cam bar locking tool from Blauparts fit the 2.8 and 2.7t?? My dads 2.7t needs to be done.
TIA
TIA
...the 4 cam seals, 2 cam plugs and two cam adjuster seals.
For the amount of effort involved in this job versus the few extra dollars for the additional parts, why not do it completely?
Yes, the pin and bar fit both engines.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2817118.phtml">Very recent (if you STFA)</a></li></ul>
E-mail me at Kyle.Johnson13@yahoo.com if you want it! I need to get rid of it... Comes with gasket too...
