Gearbox fluid - Castrol Syntrax 75W90 a GL5 or a GL4/5?
The car has turned 5 years old (Dec 2000 A4TQM B5) and done 70k miles, so I thought I'd treat it to a gearbox and rear diff oil change. There is no other reason for the change.
After checking the B5 forum, I was totally confused about what I should use in the gearbox with so many conflicing posts about what works and what doesn't, what to use and what not to use.
I called the local Audi dealer and other than the OEM fluid, they recommended something called Castrol Syntrax 75W90 for both the gearbox and rear diff, he said it was a GL4/5 fluid and ok for both.
I went to the local parts place this morning and the bottle says it's a GL5. So, it should be ok in the rear diff but should I use this stuff in the gearbox? It's not cheap either at $US25 /quart and I am going to need 5 quarts.
I am in Brisbane Australia where it never gets cold, a bit like California.
Any advice would be appreciated.
<ul><li><a href="http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002442">http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002442</a</li></ul>
DerTT
04-06-2007 08:17 AM
docmusolf
07-12-2005 12:30 PM
4ever Quattro
12v V6 Discussion
09-27-2003 02:51 PM
GoKart3
16
02-03-2003 07:49 PM
