GIAC Chip on ECU picture request. TIA I plan to socket it myself
Old 10-15-2003, 02:36 PM
BSCA4's Avatar
Old 10-15-2003, 03:14 PM
igozoom97a4's Avatar
Default I'll be tinkering with mine on Tuesday or Wednesday of next week.
I know that's not the time frame you're looking for, but that's when I'll be messing around with mine. I am putting the "stock" chip module in mine as I might be trading in the A4...
Old 10-15-2003, 03:15 PM
BSCA4's Avatar
Why do you have to socket "stock' chip?
Old 10-15-2003, 03:16 PM
BSCA4's Avatar
So you have GIAC right now? Hope you can get the close up picture of the socket and the board.
Old 10-15-2003, 03:18 PM
Žob's Avatar
Err ummm....do you have a hot air station? How do you plan on removing stock chip?
Old 10-15-2003, 03:36 PM
BSCA4's Avatar
Default Yes, I do have access to hot air station. Shhhhhhh, I am an electronics engineer so solding is my...
experty. I do have to solder 0402 components all the time.
Old 10-15-2003, 03:44 PM
Default Well...
The stock chip's removed from the board when they install the socket for the GIAC.
So, if I want to swap back to stock, I have to unplug the GIAC and plug back in this board that they're selling me with the stock program on it. (or something like that).
Old 10-15-2003, 03:45 PM
I'll do my best for you. I have a 3.2 megapixel camera, so it should be decent...
Old 10-15-2003, 06:30 PM
Delta-9's Avatar
Default I can take a pic of my stock ecu on a socket if you like.
But I am not cracking open my ECU to snap a pic of my GIAC Xchip
Old 10-15-2003, 07:25 PM
Žob's Avatar
Default Gothca...
the trick is to put the pins in the chip, then lay down a bead of solder holding them to the board. Don't worry if you cross connections with solder at this point. Once you got a good bead on both sides, you can the pull the chip off the pins and clean up the connections to how they need to be. Make sure you have enough solder down. If you don't and yank it up, you can pull a pad off the board, then you could be hating life
Quick Reply: GIAC Chip on ECU picture request. TIA I plan to socket it myself
