GL5 or GL4 in front/center diff on a Tip?
Is it safe to dump some Redline 75w-90 GL5 in to the front/center diff in a Tiptronic? Or should I play it safe and use the dual GL4/GL5 rated RoyalPurple insted?
No def answers in the past.
I would stick with the royal purple, i've used it in my quattros in the past and had no ill effects.
-Richard
-Richard
...the owner's manual. It should give you a spec for both the front diff and the center diff, but I believe that all three diffs take GL5.
The only reason not to use GL-5 in trans is shift feel and syncro life from poor engagment, it will however help gear whining in a damaged trans. GL-5 will not corrode yellow metals, brass and bronze syncros. That is an old issue and since then only de-activated sulphur additives are in use in gear lubes.
BlueRider
17
11-17-2005 04:07 AM
iceberg_slim
07-10-2002 05:45 PM
