got the measurements on the stoptech rotors
Brand new Stoptech rotors dimensions are 332mm x 32mm.
left rotor: 30.2mm
right rotor: 29.718mm
Brake pad thickness (pad material only):
.338"
.340"
.360"
.348"
the pad retaining brace is secure and bolted in properly.
<img src="http://pictureposter.audiworld.com/25289/109_0999.jpg">
<img src="http://pictureposter.audiworld.com/25289/109_1000.jpg">
<img src="http://pictureposter.audiworld.com/25289/110_1001.jpg">
<img src="http://pictureposter.audiworld.com/25289/111.jpg">
anyone know minimum acceptable thickness for the stoptech rotors? Thanks
left rotor: 30.2mm
.338"
.340"
.360"
.348"
I would guess the service limit on the rotors is around 30mm.
I can't find any info on stoptech's site to confirm that. Try searching AW.
Also, ask if the studs on the caliper mounting brackets are secure with zero play/wobble. On some kits the studs on the caliper brackets have developed some play over time.
AudiA6QQQ
14
09-16-2013 12:11 AM
Sean G
02-24-2003 07:58 PM
WildBlueYonder
9
06-27-2002 03:42 PM
