Greddy 60mm gauge Question?
#21
...start detonating IF you know what that specific temp range is.
Indirectly, it can also tell you whether or not your are leaning out or too rich just by changes in normal operating temps. If you temps start to deviated positively from your baseline, you might be leaning out. If the deviation is negative, you might be running rich.
Typically, you want to try and keep your EGT temps low to prevent the occurance of preignition.
#23
...as the probe is plumbed off the exahust tract. Generally mounted either on off the exhaust manifold or on the exhaust piping before the cat.
Variations could be around +/-100 deg.
It's all a matter of knowing your car and how it's performing.
#24
or if it was going to be something I'd have to be really looking for to find.
how hard is the installation? I know the concept but how do you actually put the sensor in?
#25
...then weld it in place to prevent any leaks.
Very straight forward. Very simple. I definite DIY if you have the equipment.
Me, I was able to drill and tap a hole but ended up paying an exhaust shop $60 for half an hours worth of welding to mount the bung. Expensive, but it was the only shop in town willing to do it.
#27
...~1 hour install time.
But, whatever floats your boat.
I guess I'm just more gung ho about cuttin' **** up in my car.
#28
here is the e-mail i got:
Hi Renzo,
Thanks for your e-mail.
For your information, our standard discount rate are at 30% discount during this promotion period. (with 10 orders)
We can offer 40% discount off our List Price for Custom Private Labeled gauges with a minimum order of 50 pcs per type per order.
The Custom Private Labeled Gauge can be any of our recent products with a custom private logo/label onto it , the same in style, quality and model and a custom private label/logo onto it.
For more details, please take a visit at http://www.omorimeter.com/private_labeled_gauge.htm
The Multicolor gauge can be custom made with red needle and a custom private label/logo onto it, offcourse a clear and clean logo/label is needed and the logo/label must not be a Registered Trade Mark example Audi Logo :-)
Please let us know how many quantity you can purchase for those custom configuration gauges for Omori Brand, a higher discount rate might be able to arrange if we can determine the actual gauges needed per shipment.
Hi Renzo,
#30
that would be with the 30% off<ul><li><a href="https://forums.audiworld.com/a4/msgs/1819150.phtml">https://forums.audiworld.com/a4/msgs/1819150.phtml</a</li></ul>
