:: GruvenParts A4 B5/6/7/8 SPC 81350 Adjustable Front Control Arms and More !!
SPC 81350 Audi B5, B6, B7, C5, and VW B5 Adjustable Front Control Arms!
*** GROUP BUY PRICING IS IN EFFECT --- SET OF 4 --- LIMITED AVAILABILITY ***
As many of you have found out, when lowering your suspension, camber and toe become misaligned which leads to expensive tire wear and poor handling. Since the OEM has made no provisions for lowering the vehicle, there is no adjustment that can be made to bring the wheels back into alignment on a lowered vehicle.
SPC has released this Set of 4 adjustable front upper control arms which will allow +/- 1.5 degrees Camber and/or Caster change for these vehicles. These arms directly replace factory fixed-length arms, allowing easy adjustments after installation. Engineered for both street and track use, forged 6061-T6 aluminum ends with large 18mm threaded adjuster links assure this is the strongest kit available. Maintenance free ball joints and bushings provide factory ride, handling, and NVH performance.
Click here to see the installation video :
These come as a SET OF 4 and fit the following models :
Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
Audi A6/RS6 (incl. AllRoad) - 1998-2004
VW Passat - 1998-2005
This product is SPC 81350 and replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
A4 / Passat 1.8T Billet Dipstick
Gruven Parts | Custom VW Parts | Volkswagen BMW & Audi Auto Parts is proud to release these gorgeous Billet Dipsticks to replace OEM part number 053-115-611C (053115611C). Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a flitting with hash marks to signify oil level min and max.
As an added bonus, this part is made to perfectly fit our Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 053-103-663 (053103663).
This billet dipstick replaces OEM part number 053-115-611C (053115611C) and fits the following vehicles :
1996 - 2002 Audi A4/S4/Avant Quattro 1.8T (AEB)
1998 – 2001 VW Passat 1.8T (AEB)
1988 – 1992 Audi 80/90
1982 – 1987 Audi 4000
1987 – 1993 VW Fox
1982 - 1985 VW Quantum 1.8L
Don’t see your car listed here? Don’t worry! We have many more of these billet dipsticks coming for nearly all makes / models. Visit Gruven Parts | Custom VW Parts | Volkswagen BMW & Audi Auto Parts for the latest.
Click Here for GruvenParts Billet Universal Dipstick Handles
Introducing the GruvenParts universal billet dipstick handle! We've teamed up with WhanAB to bring you this universal billet dipstick handle professionally CNC'd from aircraft grade aluminum. This handle allows you to retain the factory wire, stalk, and level indicator section while replacing all the visible orange plastic with a trick billet aluminum handle. This option is truly the best of both worlds – aftermarket looks using the OEM wire instead of a braided wire that could bend and provide inaccurate readings!
Choose between a circular pull handle or square to suite your needs!
Fits any rectangular steel wire dipstick. This can be modified to fit composite wires or other cross sections, but may require bonding of the billet handle.
Click Here for installation instructions
GruvenParts.com is happy to release these long awaited billet intake linkage arms for the Audi A4 and A6 with 3.0L V6 engines!
Audi 3.0L V6 Billet Intake Linkage Arms !
These billet linkage arms come two to a set – enough for 1 vehicle and will replace the plastic ones on the 2002-2006 A4 and 1999-2004 A6 with the 3.0L 30V V6 engine with rotary drive unit part number 06C-133-611 (06C133611) installed onto intake manifold part number 06C-133-201J (06C133201J).
Just like our popular Audi/VW 4.2L V8 linkage arms, these billet 3.0L V6 intake arms are Guaranteed for Life !
The OEM plastic linkage arms on these engines quickly fail due to heat and contaminants leaving your intake manifold stuck. This causes poor idle, poor drivability, loss of power, check engine lights, and poor fuel mileage. It’s a very common problem on the Audi 3.0L 30V V6 engine, an otherwise great engine. The dealer will only sell you a new actuator assembly for nearly $500 - A hefty price to pay for more weak plastic that will again break in short order.
Our Billet intake manifold arms are made from Aerospace grade 6061-T651 Aluminum with specially machined Dupont Delrin inserts to provide a perfect fit to the actuator *****.
Go with the billet GruvenParts.com linkages with the Lifetime Guarantee, save $400 over the inferior dealer plastic versions, and NEVER WORRY ABOUT THIS PROBLEM AGAIN.
This product fits the following vehicles:
2002-2006 Audi A4 including Quattro w/3.0L 30V V6 Engine
1999-2004 Audi A6 including Quattro w/3.0L 30V V6 Engine
Replaces plastic links on found OEM P/N 06C-133-611 (06C133611) drive unit w/rotary valve, which is installed onto 06C-133-201J (06C133201J) intake manifold.
Please note : You will need to disassemble your actuators to install these metal arms. Carefully pry the actuator apart (it is a snap fit). Remove the rubber bellow, and swap in our billet aluminum links. Carefully snap your actuator back together and reinstall on the manifold.
1987 – 1993 VW Fox
1987 – 1993 VW Fox
