guys, I'm installing a oil pressure gauge and i'm not sure where the sending unit is
Old 06-24-2003, 03:25 PM
Phil type 951's Avatar
Default guys, I'm installing a oil pressure gauge and i'm not sure where the sending unit is
can someone please post a pic of the sending unit on a 1.8t if you have one! thanks
Old 06-24-2003, 03:33 PM
Member
Yippers®'s Avatar
Default Sender for oil temperature and pressure:
<center><img src="http://pictureposter.audiworld.com/19399/sender_oil.jpg"></center><p>
Old 06-24-2003, 03:38 PM
nice!! thanks for the help yippers!
Old 06-24-2003, 03:42 PM
no all I need to do is figure out where that is on the car
Old 06-24-2003, 03:46 PM
Gjaime's Avatar
Look for your oil filter it's on top.
Old 06-24-2003, 03:47 PM
sweet!! thats what I needed to know!!
Old 06-24-2003, 03:58 PM
Head Cat Herder
Kris Hansen's Avatar
Default Are you sure you want to use the one on the filter for a gauge?
On my Corrado, which was an 8v I4, I used the oil presure switch up on the head..
Old 06-24-2003, 04:12 PM
Default so does that piece (#2 in the pic) meassure both temp and pressure? and
does anyone know if a vdo duel sending unit will fit on a 1.8 without adding an extention to clear the other oil lines? the fit looks a little tight!
Old 06-24-2003, 04:35 PM
yeah, that would be great, but I have no idea where it is on a 1.8
Old 06-24-2003, 06:11 PM
Member
Yippers®'s Avatar
That is the pressure switch
Quick Reply: guys, I'm installing a oil pressure gauge and i'm not sure where the sending unit is
