guys, I'm installing a oil pressure gauge and i'm not sure where the sending unit is
Old 06-25-2003, 10:27 AM
  #31
Member
Yippers®'s Avatar
Too true. Is it Granville Gulch I'm thinking of in that area?
Old 06-25-2003, 10:50 AM
  #32
Head Cat Herder
Kris Hansen's Avatar
Yep, thats' between 100 and 125 on Rt100.. Really nice bit of road.
Old 06-25-2003, 11:09 AM
  #33
Elder Member
Audi2ptzero's Avatar
Default I guess I will find out tomorrow. Should be installing the new oil feed lines
and return lines for the new turbo. We had to make our own flanges and the shop ordered all the fittings, I think they should have all the flanges and IC pipe back from the welder today. I think my next job will be to tackle replacing the fuel pump.
BTW I was able to get the wrench on the oil fitting from between the 2 intake runners and from the back side of the manifold once the coolant pipe and fuel rail were removed. I need to start taking pics soon and will try to do that tomorrow. The only real thing left is to finishing runner #4 for the manifold.
Old 06-25-2003, 11:24 AM
  #34
Member
Yippers®'s Avatar
Default Yes without the fuel rail or coolant pipe on there access should be easier.
Aligning the new oil supply line properly (from above) is the key. Goodluck .. not that you'll need it ...
Old 06-25-2003, 11:25 AM
  #35
Member
Yippers®'s Avatar
Default I lost the headlight on my motorcycle in the middle of that sucker one moonless night. About a 15.5
on the 10 scale of pucker. I didn't crash but I did spend about 10 minutes picking seat foam outta my a$$ and collecting my wits.
Old 06-25-2003, 11:56 AM
  #36
Elder Member
Default Well I already removed all the vac lines around the intake manifold
since I was planning on removing it to take the oil line out. I guess if I have to I can just remove it to put the new line in, I still have to get to the back to put my oil pressure gauge sender in anyway.
Old 10-22-2010, 12:16 PM
  #37
kenyel's Avatar
can some one tell me where i can find the oil pressure switch on audi a6 2.8 quattro please?
My94A4Quattro
12v V6 Discussion
04-01-2007 06:51 PM
unipurify
01-23-2004 10:31 PM
ianbis
06-02-2002 06:19 AM
Aleki
Audi 100 / A6 (C4 Platform)
08-13-2001 04:04 PM
Francis R.
07-23-2000 08:12 PM
Quick Reply: guys, I'm installing a oil pressure gauge and i'm not sure where the sending unit is
