Has anyone else with the Authority chip had an issue with the knock sensor?
Guest
Posts: n/a
I have had the chip in for 3 weeks and we think it may be attributed to poor fuel in Minnesota. Autothority told me that this is the first time they have heard of this with their chip. I am pleased with the performance of the chip but the knock sensor is irritating. Anyone with the same issue with an Authority or a different manufacturer when used in Minnesota?
Guest
Posts: n/a
Re: Has anyone else with the Authority chip had an issue with the knock sensor?
Do you still have a stock ECU? If so, I would put it back in and see if the problem persists. If so, obviously take it to your dealer. If not, you'll know that it's related to the chip or at least the extra power. I've heard many people point to bad gas for pinging and other problems, so there is a good chance that it is the problem.<p>JD
Guest
Posts: n/a
We live in MD. I have used AutoThority in my '99 Passat for five months and about 6K miles now, and have never had ANY problems, knock or otherwise, with the chip. I have been able to use Sunoco 94 exclusively, though.
Guest
Posts: n/a
What exactly do you mean about the knock sensor?...
The factory knock sensor is there to save the motor. If you are getting a pulsing-stuttering throttle/acceleration then the gas is too low octane or the chip is too advanced, or both. This is NOT a problem with the knock sensor!<p>Try other brands of gas, 91 oct actually varies from additive package. There are probably only a couple actuarl ful distribution companies, ask the wholesalers which brand is actually different.
Guest
Posts: n/a
Re: What exactly do you mean about the knock sensor?...
I should elaborate. It is a minor hesitation under full throttle but only if I accelerate from a low RPM up. If I accelerate from say 0-60 I don't feel it. I have been using 92 and 93 octane fuel.
Guest
Posts: n/a
It's the combination of the chip and your specific motor...
The dual knock sensor is protecting you. If it was loose, or hypersensitive, it would happen all of the time or primarily on rough roads. Your engine must have slightly higher compression. Get them to remap the chip for you.
ch7656
Audi allroad
14
02-29-2004 07:15 PM
kenny (dremel)
01-27-2003 08:10 AM
Dan Stratton
05-09-1999 05:32 AM
