Has anyone ever run 215/60 instead of 205/55 ... found a great deal on a tire
If you're going to run 60 series sidewalls (why???) you'd need to go down in width not up...e.g. to go to a 225 width tire you go down to a 50 series sidewall... a 215 puts you somewhere in between.
Why bother going to this worse performing size anyway? you can get 225/50's for little $$$
alex
alex
225/50's have the exact same sidewall height as the 205/55's
Here's how it works:
The first number is the width of the tire (in millimeters).
The second number represents the sidewall height. But it is a percentage of the tire width, NOT the actual height of the sidewall.
For example, a 205/55 tire means that the tire is 205 mm wide. The sidewall height is 55% of the width, therefore the sidewall height is ~113 mm.
DaddyWarbucks
15
03-27-2006 07:13 PM
lskolnick(original)
11
12-11-2002 11:28 AM
bigalk (back in UK)
02-15-2002 05:38 PM
